Power steering went out after donuts.
Old 12-03-2011, 06:23 PM
LaResvalosa's Avatar
I was told it is most likely the rack & pinion that got damaged. So looks like I'm gonna be spending an extra 250 at my neighborhood friendly autozone
Old 12-04-2011, 02:05 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Check for another broken pump shaft. If it's a reman pump, it may still have the old style pump shaft that break really easily.
Old 12-04-2011, 07:02 AM
livefast1's Avatar
My shop very rarely puts reman pumps on anymore. Its almost a guarantee that it will get sent back as a defect. But you should also diagnose and fix your leak as well before replacing the pump otherwise you will damage the new pump by running it low. Did you bleed the system after you installed the pump?
Old 12-04-2011, 12:03 PM
It was a duralast pump. And no I didn't blead it before cause I forgot. I blead it afterwards. Everything in place is new, the pump, rack & pinion, and outer tie end rods so now just to fill it and hope for the best.
Old 12-05-2011, 08:35 PM
Finally got it working. It was a bad rack & pinion and pump. I had to change my pump twice as my old bad rack & pinion messes up my new pump
lucas287
31
01-12-2021 06:18 AM
Superman09
09-25-2015 05:55 AM
dry_kill
11
08-28-2015 09:53 PM
1320Chicken
07-14-2015 10:58 PM
lxcoupe
07-08-2015 05:49 AM
Quick Reply: Power steering went out after donuts.
