PPV Brakes on NNBS
#51
Paging @Drspencer come in spencer
Have you made any more progress on these brakes?
I almost want to just put on some of those 20s that Dan posted earlier and eventually find a nice after market wheel.
Drspencer (10-02-2022)
#52
My bad. Definitely missed this one. Alright. A BIG update…..they’re installed. They do great things. No rattling. No humming under heavy braking or load BUT…. For those trucks with 13” rotors, there is a part of the inside of the pad, 1/4” at the peak of the radius, that is NOT on the rotor surface. This can cause low speed, low pressure squealing. And it’s Fuggin loud. To rectify this, you just take a grinder to the affected area, the area that is not touching the rotor surface.
shakenfake (07-05-2022)
#53
Pics or it didn't happen
#54
Fullpower (07-05-2022)
#55
Yes, I’m just chamfering the edge only where it’s overhung on the inside. The mention of 13” rotors is for vehicles originally equipped with 13” rotors. The 2019+ had 13.5” rotors meaning the caliper mount is 1/4” outward. The 16” rotor package was made for vehicles originally equipped with 13.5” rotors.
#56
I just need to know if these or Centerline Stingray IIIs will fit lol
Those Welds I wonder if they would be able to not make it a gloss black, would not look good on my truck imo
Do y'all know if snowflakes fit?
#60
Not to chage directions of the thread, just trying to share the info I discovered with my setup. I decided to buy the 6 piston Brembo brakes that a 2023 Escalade ESV-V from Rockauto. But did discover the cheap Dynamic Friction brake pads RockAuto sells won’t fit. They are missing the correct holes for the brake pins. I had to use AcDelco pads. For reference, I bought the newer GM 4 piston caliper set just to take them apart and dissect. The smaller coated pistons shown are from the Brembo 6 piston caliper. The larger uncoated pistons are from the 4 piston caliper. The piston diameter of each, and total surface area is less vs the 4 piston calipers. Witch actually pairs better with the older truck’s smaller master cylinder. Most of the braking performance of the 6 piston kit relies on the larger pad friction surface and 16” rotor anyways, not number of pistons. Since it’s a fixed caliper, I did have to shim the Brembo caliper 3.25mm or slightly over 1/8” to center the caliper on the rotor. In addition, for my wheel to fit over this large caliper, I ended up using a 1/2” wheel spacer.
