problem installing gears
Old 05-11-2009 | 09:19 PM
therock's Avatar
@ axisT6,
Thanks for helping out here.
I would like to ask more about break in between AAM and other mfg gears. Do the GM OE gears and their claimed 1500 degree heat treating require the same 500 mile deal as the others?
Old 05-11-2009 | 10:48 PM
lady3bglover's Avatar
Originally Posted by axisT6
Oh. Well, ideally you should put 500 miles on the gears before you run them on the track. If that is not possible, then at least drive the truck for 30 minutes preferably down the highway at no more than 60 MPH. Afterwards, park the truck and let the differential cool completely. That will at least get the initial break-in done.
If you choose to fully break them in, after the initial break you should drive the truck as if a cop is behind you. No hard starts, no hauling, no towing till you 500 miles. Keep your speed under 60 as well.
Hey, you forgot to tell him to check the fluid... don't you remember how I broke the bed of the truck going over those damn ramps?
<< Agrees on the 500mi break in period.
Old 05-11-2009 | 11:49 PM
Dark Halo's Avatar
I still have some slack after changing everything to new parts, could my crush sleeve be wrong? how much paly should the pinion have?
Old 05-12-2009 | 09:52 AM
Dark Halo's Avatar
anyone have a pic of the crush sleeve they have used?
Old 05-12-2009 | 08:12 PM
Grumpy5.3's Avatar
The proper amount of preload for the pinion is 14-19 in. lbs
I am curious, where do you get your specs from??? According to service information, yes I am a GM tech, it is 25-35 inch pounds with new bearings??
Just curious how other people do things, not doubting you....
Old 05-13-2009 | 02:10 AM
Dark Halo's Avatar
Im sorry to sound dumb but how is the preload set? I have put alot of force on the nut to install the pinion and I dont think I have even crushed the crush sleeve yet. I am just wondering if you apply enough force to crush then back off and preload to 25-35 inch pound? Also why so little?
Old 05-13-2009 | 12:53 PM
silver-mod-o's Avatar
Hunt&Fisherator
Eric, I went out and looked at my axle... If you grab the pinion by hand, there will be some slack, I really can't tell exactly how much, but it does turn back and forth... I'd guess its like we talked about, its the pinion moving back and forth in the ring gear slightly.
Old 05-13-2009 | 04:47 PM
Dark Halo's Avatar
I am going to try and get the sleeve to crush today or tomorrow
Old 05-13-2009 | 07:17 PM
Grumpy5.3's Avatar
preload is set by crushing the sleeve. The pinion will move in and out of the diff untill you get the nuttight. When you get it tight, the pinion will not move in and out, then turn very little because you will be adding preload after that. Do not over tighten then loosen it, tighten very litle at the time.
Old 05-13-2009 | 08:03 PM
Dark Halo's Avatar
ok, that makes sence apply proper toruqe to the nut to crush then pre load. Will the nut turn easier after the sleeve crushes?
LCHEE
10-24-2020 05:10 PM
thunder550
10-08-2015 05:53 PM
iregret
07-27-2015 11:31 PM
lxcoupe
07-21-2015 03:12 AM
ferrellrooster
07-13-2015 10:53 AM
