pulled the trans
Old 05-22-2008 | 08:16 AM
TURBHOE's Avatar
Default pulled the trans
man that was a job. do they always seem to be glued to the motor? i had to pry for hours to get it loose. any body know a good way to put the t-case and trans back in? should i pull the torssion bar mount? or just bolt up the trans and then bolt up the t-case? oh and the trans fluid STUNK!!!! never smelled anything like it before.
Old 05-22-2008 | 08:25 AM
mcfarlnd's Avatar
Un-Registered User
good to hear your getting it done. when we took my tranny out, it pulled right out. was the fluid burnt?
Old 05-22-2008 | 09:36 AM
RED04REGENCYRST's Avatar
suggestion on the trans sticking to the engine. i put anti-seize on the two studs on the motor side and all around the bell housing. its what i did to my manual trans and i havent had a problem since.
Old 05-22-2008 | 11:42 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Seem to remember the time white1 installed his FLT L5. I distinctly remember three of us under the truck, with two working, and one supervising. We put the trans and t-case in as one unit. Will say that is one HEAVY combo without help.
Old 05-22-2008 | 11:56 AM
Banned
i usually put the tranny first then the transfer case
Old 05-22-2008 | 11:59 AM
thunder550's Avatar
High on diesel fumes
I pull the t-case first, then the trans. Then reverse for reinstall.
Last time I did it, laying on my back, it took all of about 15 seconds to get the t-case reinstalled onto the end of the tranny. No reason to pull the t-bar crossmember.
Old 05-22-2008 | 01:31 PM
TURBHOE's Avatar
it seems like when i did the silverado trans that is what i did. trans then t-case. i took some of the fluid to work and the lok on peoples face when they smelled it was great. its very dark and the pan has lots of little pieces in it. i took pics. i'll post them up in a second.
Old 05-22-2008 | 01:34 PM
TURBHOE's Avatar
yeah, and if i remember right it had about 200 miles on it when we did it. pretty funny when your stall is has as many miles as your whole truck.
Old 05-22-2008 | 01:44 PM
TURBHOE's Avatar
here they are just click to make bigger
/npics of the turbo tahoe
/npics of the turbo tahoe /npics of the turbo tahoe
Old 05-22-2008 | 01:59 PM
Mean03's Avatar
i just pulled my trans also...the best way is to stab the trans first then bolt the t-case on after the trans is up..that t-case weighs 85lbs
