putting in converter...need advise.
LS1TECH & Trucks Sponsor
Cool Unhook all wires from the transfer case and the trans with the exception of the PRNDLE switch plug at the manual linkage if you need to remove this remove the linkage and the two bolts and slide it off the manual linkage shaft as the plugs are bad to break up on removal, Sorry couldnt stay up any longer last night 2 AM is late for me, Holler if you need anything and hope I was of some help
Frank at PerformaBuilt
Again............Thanks!! Last night I removed everything except the torsion bar mount. I think I have enough room to move the trans back and drop the front to access the converter. This is going to be messy. What wires/connectors do I have to dissconnect to make sure they dont get torn in the process?
It is!! the trans is up, and all bolted together. Now I'm installing the pacesetter LT's and Y. Much easier with the crossmember out!! That was'nt to bad actually!
AHelm3
04-08-2016 07:51 AM
05GMC4.8
08-07-2015 09:55 PM
