putting in converter...need advise.
Old 01-19-2008, 01:29 PM
LS1TECH & Trucks Sponsor
performabuilt's Avatar
Cool Unhook all wires from the transfer case and the trans with the exception of the PRNDLE switch plug at the manual linkage if you need to remove this remove the linkage and the two bolts and slide it off the manual linkage shaft as the plugs are bad to break up on removal, Sorry couldnt stay up any longer last night 2 AM is late for me, Holler if you need anything and hope I was of some help
Frank at PerformaBuilt
Old 01-19-2008, 02:29 PM
kbracing96's Avatar
Originally Posted by Blue06
Again............Thanks!! Last night I removed everything except the torsion bar mount. I think I have enough room to move the trans back and drop the front to access the converter. This is going to be messy. What wires/connectors do I have to dissconnect to make sure they dont get torn in the process?
Yep you can drop the front of the tranny down far enough to swap the converter without pulling the t-bar crossover, I did it when I did my stall.
Old 01-19-2008, 03:12 PM
Blue06's Avatar
Workin on it right now. Waiting for the lines tools to get the trans lines off...........then its out.
Old 01-19-2008, 04:12 PM
Blue06's Avatar
VICTORY!! converter is in. Now I just have to jack the front of the trans up.
Suprisingly no mess........not a drop!
Old 01-19-2008, 04:21 PM
Make sure converter is fully seated!
Old 01-19-2008, 05:22 PM
Blue06's Avatar
It is!! the trans is up, and all bolted together. Now I'm installing the pacesetter LT's and Y. Much easier with the crossmember out!! That was'nt to bad actually!
Oobray
06-13-2022 03:38 AM
shawn96gmc
05-17-2016 04:15 PM
AHelm3
04-08-2016 07:51 AM
chevy6.0fan
08-20-2015 07:10 PM
05GMC4.8
08-07-2015 09:55 PM
Quick Reply: putting in converter...need advise.
