Qa1 question
Qa1 question
Looking to pull the trigger on a set of qa1 12 way adj. for the front of my 2wd 2002 Silverado. I'm currently running 2" lca's on the front. I've done a lot of reading and I just won't to see if you guys think about the setup that speed engineering sells for our trucks. Is this what I need to get them on?
Links to the shocks
QA1 Motorsports TC1958P - QA1 Front 12-Way Adjustable Shock (Stock Or 4 Inch Drop) | Speed Engineering
QA1 Motorsports BAR350K - QA1 T-Bar Conversion (Required To Fit Late Model Trucks) | Speed Engineering
Links to the shocks
02 w/ lowest mileage 2800
The shocks above will work, but will probably hurt more than help at the track due to the lack of extension. The t-bar can be mounted above the a-arm to gain back some extra travel. The next size up that qa1 sells has 15.5" extension and is part number ts502, td502, or tr502 depending on adjustability. You'll need the 3.5" t- bar kit.
TAPyvehc93
09-12-2015 08:19 PM
carid
09-10-2015 09:07 AM
