question: performance + leaf springs
Old 06-12-2012, 11:58 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Are you sure its not the front end??? Like loose wheel hubs or bad inner / outer tierods
Whats been done to your rear differential??? Open, Locker, or Posi differential???
Old 06-13-2012, 05:44 AM
TXSZ66AVLANCHE's Avatar
The steering is tight, pretty sure the problem is not in the front end. Rear diff was open, now has a truetrac. The swaying started well after the tt was installed, made sure both wheels are getting power by leaving a nice set of twin stripes on the road
Old 06-13-2012, 11:23 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Is it swaying with your street tires, or your track tires? Or both sets? Are the track tires radial or bias?
I'd like to see a printout of the wheel alignment if you can post it up. That could show a problem if there is one with steering/suspension geometry. There's other things to check also, like set-back, worn parts, cracked leafs, etc.
Old 06-14-2012, 05:47 AM
Only street tires, no track tires yet.
Old 06-14-2012, 11:19 AM
1FastBrick's Avatar
It is possible that the rear end is not centered in the rear and your fighting it under load. You would have to separate the leafs from the axle and check the pins.
Do you know the history on the vehicle? I.e. if it was ever wrecked or possibly abused in the past???
Old 06-14-2012, 11:59 AM
Carfax showed one owner in San Antonio since New, also listed as a new vehicle trade in. Serviced and state inspected from same selling dealer since new.
Old 06-14-2012, 07:28 PM
Wide Open's Avatar
You have a chance to get it on the alignment rack yet?
southernsmoker
08-31-2015 03:09 PM
nickpc82
08-10-2015 09:08 AM
signguy62
07-27-2015 03:42 PM
lxcoupe
07-24-2015 06:01 PM
Mike454SS
07-20-2015 08:52 PM
Quick Reply: question: performance + leaf springs
