Quick Question on 2/4
Old 07-10-2008, 12:17 PM
carfreak07's Avatar
Default Quick Question on 2/4
I searched for a while but ran out of time on my lunch so I am going to ask. I have a rcsb silverado with 2"drop shackles in the back.....i guess thats what they are called! Anyway I want to lower it two more in the back and 2 in the front for a total drop of 2/4.
Can someone tell me exactly what I need to buy to complete this. I know springs for the front but I cant find any shackels that will lower it four inches in the back. I might cut one round out of the front springs, I read that on here but i'm not sure about that either.......any advaice you gus can give me will be great. Sorry if you have answered this before but I am tired of searching with no answers.....thanks a bunch in advance!!
Jarrod
Old 07-10-2008, 12:22 PM
Wearin' da big hat
00ChevyScott's Avatar
do a 2" hanger in the back too. Its a bit of work, but its good if you want to have it ride good.
Old 07-10-2008, 12:24 PM
Hef45's Avatar
u need 2" drop hangers (belltech, djm) in the rear, or if u still have your stock shackles u can get some 4" drop leafsprings (hotchkis, ground force). The leafs will give you a stiffer ride.
Old 07-10-2008, 12:31 PM
carfreak07's Avatar
yes I would like to contain my factory ride.....so I just need 2" hangers? Leave my 2" shackles and cut my factory springs or should I just get a complete kit?
A friend of mine has a 4/6 kit, can i make this a 2/4 or is that out of the question?
wHAT ABOUT THIS KIT??
http://cgi.ebay.com/ebaymotors/ws/eB...rksid=p3286.m7
Old 07-12-2008, 10:52 PM
2001CamaroGuy's Avatar
get a set of 2" drop spindled for the front and a 2" drop hanger for the rear. this will keep 100% stock springs and will maintain factory ride quality. I have the belltech drops on the front and have had zero issue with them.
if you do ANYTHING to ANY springs, you WILL change the ride quality
Old 07-14-2008, 08:55 AM
carfreak07's Avatar
Ok, thanks for the advice! Anyone else??
Old 07-14-2008, 10:58 AM
chevytruckguy's Avatar
The closest you can get to 4" drop in the rear from a flip kit is a 5" drop (flip kit with lifting shackles or helper bags). The front will depend if its a coil/spindle drop or a control arm drop. If the front is a 4" control arm, thats all you're getting. If its a spindle/coil drop, you can use either the spindle or coil.
Old 07-15-2008, 02:23 PM
carfreak07's Avatar
Ok, I dont want to go any lower than 2/4.........
In order to retain my factory ride, what do I need?
FRONT:
Spindles?
Aftermarket Springs?
My Factory springs with one coil cut?
Rear:
2" Hangers with my 2" shackles??
Something else?
Which of each of these items are the best to keep my same ride? I am dying to order them but have not seen any real solid answers to my questions yet. Thanks a bunch in advance!!
Old 07-15-2008, 04:16 PM
slw ls1's Avatar
2/4 Kit 1
2/4 Kit 2
2/4 Kit 3
Don't know what year your's is, but I've been looking for my NNBS and these are the ones I've found on ebay. I don't really know how good of quality they are though.
Old 07-15-2008, 04:18 PM
95 bright teal's Avatar
Like 2001 camaro guy said, spindles hangers and your shackles will give you a 2-4, you will want shorter bumstops or a cnotch, either way your ride will reamin the same just lower
Quick Reply: Quick Question on 2/4
