random clunks
Old 02-24-2005, 09:15 AM
Mr. Sandog's Avatar
I'll try and locate the TSB #'s and post them here.
Old 02-24-2005, 09:25 AM
that would be greatly appricated.. thx man!
this is for the 04 model
Old 02-24-2005, 09:36 PM
Mr. Sandog's Avatar
Okay, are you sitting down?
1. #PIT3456 Re-Manufacturing Old I-Shaft and Part Number Change -
keywords 00-02-35-003G clunk noise steering shaft vibration wheel
suspension column - (Feb 23, 2005)
2. #PIT3459 Torsion Bar Crossmember Bushing Replacement - keywords
suspension clunk pop loose broken break front bracket insulator - (Feb
22, 2005)
3. #PIP3340 8.25 and 9.25 Left Front Axle Shaft Difficult to Remove
- keywords bind clash clunk differential drive engage fork gear hard
inoperative knock moan noise odor overheat rattle repair seal seized
stuck - (Feb 16, 2005)
4. #99-04-20-002C Info - Driveline Clunk Noise When Shifting Between
PARK and DRIVE, PARK and REVERSE or DRIVE and REVERSE - (Jan 31, 2005)
5. #01-04-17-004B Clunk, Bump or Squawk when Vehicle Comes to
Complete Stop or Accelerating from Complete Stop or Accelerating from
Complete Stop (Replace Rear Drive Shaft Nickel-Plated Slip Yoke) - (Jan 5,
2005)
6. #PIT3118B 01-05 Chevrolet/GMC/Cadillac All Full Size Utilities
Pop Clunk Click Noise on Right or Left Turns - kw suspension floor pan
body mount bolt steering clunk insulator shim - (Nov 19, 2004)
7. #PIT3243 01-05 Chevrolet GMC Cadillac All Full Size Utilities
Pop/Clunk/Click Noise on Right or Left Turns - kw - (Oct 28, 2004)
8. #00-02-35-003G Clunking Noise Under Hood and Can Be Felt in the
Steering Wheel (Lubricate the Intermediate Steering Shaft Assembly) -
(Oct 22, 2004)
9. #PIP3106 4L60E/4L65E Snap Noise 2-1 Downshift - kw 136 149 233
236 246 4L60EHD automatic bind clash clunk drive engage grab hard harsh
second shift - (Sep 22, 2004)
10. #PIT3144 99-03 Chevrolet/GMC/Cadillac All Full Size Trucks and
Utilities and Hummer H2: Supplement to 00-02-35-003F Clunking Noise Under
Hood and Can Be Felt in Steering Wheel - kw shaft vibration suspension
- (Aug 27, 2004)
11. #PIT3060 Loud Grinding Growling Noise from Rear of Vehicle after
Hitting Bumps - kw GMT800 GMT805 GMT806 GMT820 GMT830 bind boom
brake buzz chatter click clunk contaminated decelerate differential disc drum
- (Jul 9, 2004)
12. #03-03-09-002A Rear Leaf Spring Slap or Clunk Noise (Replace
Spring Insert and Insulator) - (Apr 29, 2004)
13. #PI01634A Service VME - Supplement to 00-02-35-003D - Clunking
Noise Under Hood and Can Be Felt in the Steering Wheel - (Apr 21, 2004)
14. #01-07-30-042B Information on 2-3 Upshift or 3-2 Downshift Clunk
Noise - (Jan 16, 2004)
15. #PI00748A Grind/Rachet Noise Occurs When Shifting into Park While
in 4 Wheel Drive Low - kw 226 233E 236 241 243E 246 246EAU 261 263
4L60E 4L65E 4L80E 4L85E 4LO Allison bind case clunk grind LCT1000 LO4
noise - (Dec 16, 2003)
Courtesy of a friend over at the Chevy Avalanche Fan Club
Old 02-28-2005, 12:35 PM
22, 2005)
2005)
(Oct 22, 2004)
- (Aug 27, 2004)
- (Jul 9, 2004)
Very Much Appreciated!!!
Old 02-27-2006, 01:38 AM
ridered4life's Avatar
ok bud i know EXACTLY what it is and its a $20 fix. there is a crossmember that connects your lower a-arms. one side of the cross member is slotted for god knows what reason. GM's fix for this is take off the crossmemeber, grind off the anti-corrision crap they put on it, slap some anti-seize on it, put 4 washers on ONLY the right side, and torque it to 100 ft/lbs. its really easy and only takes about an hour. good luck
Old 03-01-2006, 12:16 PM
are u serious? wow, that is janky! lol
dantheman1540
02-24-2016 09:56 PM
legerwn
56
11-15-2015 10:21 PM
Velocity1
10-02-2015 08:01 AM
01silvy
09-26-2015 10:20 PM
Brandonlflr12
09-08-2015 09:01 PM
Quick Reply: random clunks
