RCSB vibrations
11 Second Club
My 99 GMC did it very bad I took it to my local dealer,they had the tires rebalanced and had the front realigned.That didn't do anything,The last time I took it in they had a GM rep look at it he told them to put a pinion angle gauge on it and get my pinion at a certain degree. I can not remember what angle they set it at,but they did use 2 deg. shims.
i have a rclb and it vibrates alot to brand new tires so they are balanced alum rims alignment is current and true, also rebalanced my driveshaft mine shakes from about 65-75 and intermittentally etc.
i'm going to check the pinion angle tomorrow.
anyone know where i can buy shims?
My 99 Sierra RCSB vibrated badly! I took it to the dealer 7+ times and never got it fixed, I just gave up. They re-balanced the tires a few times. Told me it was the tires and they wouldn't warranty them (only 20k miles!!!!). I put a set of brand new Perelli's on it and same thing. They replaced the driveshaft and so on. I also had a problem when I came to a complete stop, it would have a "slamming" action in the rear, like the rear end or suspension was loose. I gave up on that truck and got my '02 and have never looked back and have been very pleased.
Originally Posted by negativeswitches
i ahve a thunking action in the rear soemwhere when i stop hard or accelerate hard after stoppong hard
everything is tight i cant think of a single thing it could be
hmmmmmx i've had the d-shaft off 3x last year all diff occasions and i never thought to clean them jsut one of those things you pass up i guess....
thanks man i'll give it a try
-Erik
-Erik
I had a bad shake at 120 kph that got bad enough to cause the aluminum tailstock housing of the trans to explode. I thought the driveshaft was bad, so I got a new transmissions and got a custom steel driveshaft for the truck. As soon as I hopped in for a test drive I hit 120 then whammm, bam, bam,bam the outputshaft of the trans had sheered off and the driveshaft was flailing around, oretty quick to since I had 4.10's. So 2 transmissions and 2 driveshafts have been trashed now.
I pulled the rear dif appart and found a worn pinion gear, adding a new ring and pinions solved all my problems.
I can now pull it up to 200 with no shakes now. An expensive way to find diagnose a vibration.
peace
Hog
peace
Hog
xtrooper89
09-21-2015 06:03 AM
