Rear brakes swapped, now WTF is this noise?
I swapped out to the SUV dual piston rears to match my 13" fronts, now I have an intermittent noise. It only happens as I turn to the right, and I believe it is the drivers side rear. It goes away as soon as I straighten up or turn left. Here is a video. http://dl.dropbox.com/u/38631649/201...-17-46_711.mp4 Let me know if you can't get this vid.
Interesting thing is, when I first did the brakes, they were making this same noise constantly, but it went away after my first 70-0 stop when I was giving it a shakedown to see how the bias was compared to the fronts. I'm thinking there is still a bit of brake pad trimmings on the edge of the pad making this noise but wanted to see if anyone else had come across this. Thanks.
What all did you change? Mine made a similar noise when I swapped rear ends and put my disks on the new rear end. It ended up being my dust shields touching the rotor in one tiny spot. It took me more than a week and taking my wheels of at least 10 times to find.
Yep, dust shield. It's interfering with the caliper bracket. I bent it out with my fingers slightly and the noise is almost gone. I should probably mark the area the bracket is overlapping and snip it out with tin snips but don't really feel like fighting with my now broken floor jack.
I posted this on another thread a day or so ago.
So I know people are worried about the rears locking before the fronts, I can most assuredly say this is NOT the case when you use 05+ fronts and the SUV rears. I just did the swap with new rotors and ceramic pads all the way around on my SBSC and it works excellent. Fronts start to lock slightly before the rears and of course the ABS unit takes it from there.
Steve-O-08
04-19-2018 09:32 AM
SLOPONY
20
10-18-2016 06:05 AM
mrgrim
07-08-2015 08:12 AM
