Rear Detroit TT Install
Guys,
Within the next few weeks I am going to try and install my first set of gears and carrier. OEM 4.10's with a Detroit TrueTrac. I've bought a complete NOS front differential with 4.10's to cover the front end gear swap.
I am going to time it with a suspension drop. Lower control arms up front and hanger shackle change in the rear.
I am thinking that since this is my first install and since I'll be deep into the rear suspension that I will just pull the whole rearend and get it out from under the truck to help with the setup. Am I
? Should I just leave it in the truck and do it there? I don't have a lift. Will be doing it on the garage floor.
![Crazy](https://www.performancetrucks.net/forums/images/smilies2/crazy.gif)
You might want to shoot AxisT6 a PM for any install tips and info. As he is the rearend guru around my area and really knows his stuff. With OEM (AAM) 4.10's the backlash is very tight (3-6 thousandths) and will be much harder to install than a quality aftermarket gear such as Yukon. Just something to consider since this is you first install.
Think about your driveshaft balance, and maybe a safety loop. That's what I'm going to do. The factory balance on the truck shaft leaves alot on the table. I'm going to go with either a chrome-moly, or aluminum shaft with 1350 universals, and a highspeed balance. I bought a loop today at Summit, just have to modify it to fit on my truck. The driveline on our trucks is pretty good, already, but with a good driveshaft with 1350 universals, it should never give you problems. If you decide to go that way, look into getting a pinion yoke for 1350's while you have everything apart. Maybe some c-clip eliminators, too. Man.........it just keeps going on, and on! IT NEVER ENDS!!!!
Originally Posted by 4.8T
i did both my detroit installs with truck on jack stands and rearend in place. i recomend removeing the sparetire and tire hanger. because it will **** you off when you nail your head on it. lol
Thanks for the tip... I'll drop the spare. Need to anyway. Its never been out from under it.
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
Originally Posted by KySilverado
Looks like another dive under the truck.
the hanger only has like one bolt holding it on too. i leaned back and smacked my head on it. it came out quickly after that.
![Bang Head](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_banghead.gif)
Dezert1500
07-30-2015 02:51 PM
