rear diff fluid and g80
Old 11-02-2005, 07:43 PM
stone150's Avatar
Default rear diff fluid and g80
do i need friction multiplyer for my rear diff, some one said the g80 dosen't require it, is this true and what should i go with?
Old 11-02-2005, 08:47 PM
SnakeOiler's Avatar
No, just make sure you put 75W-90 synthetic in it
Old 11-03-2005, 10:15 AM
Mort's Avatar
Cool
Old 11-03-2005, 02:01 PM
stone150's Avatar
ok good, i put some in it last time, but i have to redo it and i will save me some money. thanks
Old 11-03-2005, 04:50 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Per Gm's instructions you are suppose to use the friction additive. Without it you will get shirping rear tires when you go around corners and also I have heard alot of people having problems with the synthetic stuff though I havent had any personal experience with the synthetic.
Old 11-03-2005, 05:00 PM
TurboGibbs's Avatar
The g80 I've worked with had clutches as well as the mechanical lock. The clutches aren't as strong as an eaton's of course. I would put the friction modifier in it. K&W makes some. they sell it at most parts stores. Some fluids come with it already in it. Read the bottles and see.
Old 11-03-2005, 07:13 PM
stone150's Avatar
ok once again i am confused
Old 11-03-2005, 07:46 PM
1slow01Z71's Avatar
If its got the G80 in you need to use the friction modifier with mineral oil 75W90 or something close to that. I promise, I put some more friction modifier in my rear axle to when it started chirping around corners and it helped for a while then I did a nitrous assisted burnout from the shoulder of the road with one tire in the grass and basically melted it together into one solid chunk. Had to be cut out with a torch and grinder to put the eaton
Use the modfiier its like 3 bucks and cheap insurance and also what GM calls for in their service manuals
Old 11-03-2005, 07:58 PM
SnakeOiler's Avatar
My GM service manual and my owner's manual calls for 75W90 Synthetic. Neither mentions the additive.
Old 11-03-2005, 08:03 PM
1slow01Z71's Avatar
Im just going on what the parts guy at the local dealership said was in THEIR tech book not if it doesnt show up in yours or he was lying to me I dunno but I do know they add the friction modifier when they do any rear end service at Champion Chevrolet in Athens, AL.
Quick Reply: rear diff fluid and g80
