Rear End
Rear End
Okay well my stock reared finally decided to give out on me. I was just wandering what you guys are putting in these for what i have done to the true already. i wanna go up to 4.10 if y'all think thats good but what about truetrac or any other rearend components.
Custm2500's Rude Friend
There are several things that could break. The most common is the differential. If its an open style, the spider gears could break and take everything else out. If its a factory locker the ramp plate usually lets go and takes everything else with it. Most common causes are lack of maintenance and burn outs.
4.10's would certainly help in the performance Dept. If your going to rebuild the 10 bolt, you might want to try a Detroit True Trac. They seem to be the most durable unit to take the punishment.
Plenty of fast guys with 10 bolts on here
If you really plan on beating the Snot out of it like launching on slicks, you may want to look into a 14 bolt swap.
That's about all you can really do besides maybe getting stronger axles.
The only other thing would be to have some one inspect the housing for straightness and possibly weld the Tubes to the center section. Not mandatory but it might help with longevity. Every factory housing I have seen has some deflection in 1 direction or another and requires a little straightening.
Good luck, Keep us posted!!!
