Rear end help!!
Rear end help!!
My grenade 80 blew and im not putting another one back in. I need help on picking out a new one. I have a 02 ecsb z71 with 285 70 17s. What would you all reccomend?
I have an auburn unit in mine and am extremely happy with it! I am 8.5" 10 bolt in a regular cab short bed. You may have a 14 bolt, not sure if they make one for that or not....I never have checked....good luck
I have an Eaton posi and I like it, but if I were to get one now I'd lean towards the truetrac. They're both good. If you off-road your truck you might like the true trac. I've heard somewhere that they can get you traction even if one wheel is in the air, something about applying brakes and giving it gas to get the truetrac to act like a locker. If you do a search, you'll probably find it.
I used to have an Auburn pro in a 5.0 mustang, and I like that one alot, the only downside is when they wear out the case is not rebuildable. They do have some warranty, though.
TimDave217
08-24-2015 04:38 PM
shupe
08-05-2015 06:45 PM
