rear end issues
the gears and shim kit came from me. when i ordered them i told ron i had a 8.6 rear with 3.73 and g80 and wanted to go to 4.10's he picked out everything and i just never used any of it. maby that tru trac is for 2xx and numericly lower? sounds like a ring gear spacer might fix it. but at the same time you would think ron would have sent him the right tru trac for that ratio?
1 Post
Talked to ron allready
Tru trac part number is a 913A481
Gears are a oem 4.10s from rons also
there is only one true trac type carrier for the 30 spline axles
1 Post
Turns out the "oem" gears are thinner than my previous set of us standard gears.
I guess i need a ring gear spacer or a new set of gears.
I just put my new tru trac in with my worn 4.11s and it whines horribly now but after a month without my truck i really needed it back.
1 Post
What exactly is this? I have not heard of any thing like this. Do you mean the carrier bearing kit from the lowering kit?
I would like correct gears but i really dont have the money to throw at a 3rd set of gears, i might just end up with a ring gear spacer.
1 Post
i have all belltech stuff but i have not got the carrier bearing relocater, my angles are pretty good and i dont think i absolutly need one.
Any suggestions on whether i should just get new gears or a ring gear spacer?
