rear gears for turbo set up...
Old 10-16-2008 | 07:43 PM
JakeBrakeIH's Avatar
Default rear gears for turbo set up...
Im getting everything set up for my upcoming t56 swap and i need to chose a gear ratio for my truck...i originally planned on something like 4.88's but now that ive gone a different route and am going to turbo charge my truck, i had read that the turbo setups like to be lugged a little bit...but seeing my truck is and ECSB with 20s with roughly a 30" tire on it, i didnt know what gears to use...
the motor is gonna be a foraged 408 and hope to get the KBracing front mount kit...so what do you guys think...4.56, 4.88, 5.13? oh and BTW, wheres a good vendor to get them from...I want to get a tru-trac as well while Im doing the swap...
thanks
Old 10-16-2008 | 07:51 PM
viciousknid's Avatar
Where's the Beef?
3.73's. The larger the gears the longer the lag will be.
Get something like 3.73 and you'll see power sooner.
Edit: or should i say STAY with your 3.73's
Old 10-16-2008 | 07:57 PM
3.73's with a t56...hmm maybe im confused...i thought the higher the numerical number, the lower the ratio, hence 3.73's would be A LOT of lag where as 4.88's or 5.13's wouldnt have any lag at all? but thats why im askin you guys...
Old 10-16-2008 | 08:02 PM
Where's the Beef?
https://www.performancetrucks.net/fo...d.php?t=423653
I can't find the thread that talks about lag difference. but Spoolin went from 4.10s down to 3.42's.
I'll keep looking
Old 10-16-2008 | 08:05 PM
95 bright teal's Avatar
Yep NA i would say go with 4+ but turbo you will pull through the gears too fast, not spend enough time in the powerband. with a t56 i would say either 3.73 or 4.10.
Old 10-16-2008 | 08:08 PM
nonnieselman's Avatar
I'll keep looking
But remember he is goin with a T56..
Spoolin went from 3.23s to 4.10s to 3.42s with the 80E.
He is running quite a bit of boost so it might be a different game.
If I were you, I would leave it like it is to see where your over all gear ratio is. then decide which way to go.
Where's the Beef?
found it
Originally Posted by Spoolin
I'm 2wd with 4.10's, but with this combo I'm not loading up the engine/turbo enough in 1st and 2nd gear to see full boost, and blow through the gears way too fast.I figure if I make my gearing a little shorter I can get better gas mileage, load up the turbo better in lower gears, and consequently stay in my power band a lot longer as well.I think I'm gonna get 3.42's. Power isn't my problem, it's the other things in my set-up.
Originally Posted by charcold-bowtie
So you really think the gear swap was worth it. I have 4.10 in mine right now, but have a set of 3.73 i could trade someone.
After driving around for the last few days with it I can definitely say that yes it was! My truck feels stronger in every gear in AND out of boost which I wasn't expecting. I'm seeing a good load on the engine in every gear now and am able to make full boost in every gear but first which I'm still seeing 16lbs. Even around town driving it's much more enjoyable. Feels similar to dropping from a 3600 TC to a 2600 TC. I would recommend if for anyone pushing alot of boost or who have alot of Torque.And now I won't be shifting into 4th 120 feet before the beams at the track! Should be at the top of 3rd at around 120mph...hopefully!
Old 10-16-2008 | 08:13 PM
Where's the Beef?
Yea I forgot about spoolin running an 80e and gt76
Old 10-16-2008 | 08:15 PM
thats probably a good idea to just leave em, and seeing im got a GTO t56 with overall lower gear ratios it might work out for me...lol but i wasnt planing on doing the t56 and motor and the same time...haha that will be fun to drive...t56 + 4.8 + heavy truck=a handful to drive until Im boosted...regardless i will need a locker if these gear work for me, which do you guys like to run?
Old 10-16-2008 | 08:16 PM
Where's the Beef?
I picked up a truetrac. but can't comment until i get it put in.
