Rear Sway Bar??????
Update......
Hey fellas I installed my Hellwig rear sway bar today as well as my Prothane Polly bushings on my front sway bar. The front end links did need to be trimmed down to clear the rubber brake lines, but we went for a test drive and the front end dosen`t roll over as much and it is putting a beating on my stock General tires now. I mean what do you expect putting that much pressure on soft side wall tires with the new setup. You can now feel the tires side walls roll over and then start to grab. Now the rear sway bar was a bitch to install becauce of the self locking nuts, but other than that the install was simple and to the point. The fugged up thing was that it was raining here in Houston for the test drive so I didn`t get a chance to corner hard. I did do some hard left and rights on a straight road and I did get the tail end to come around on me a bit. Even when I take neighborhood corners and normal speed the rear seems to follow with the front of the truck a whole lot better. It almost feels like I shortned the wheel base. I can`t wait untill the weather dries up so I can see what she really will do. I hope it`s not to loose because this truck dosen`t have the power to correct it like the Camaro dose. I`ll get back with you fellas when I get a chance to corner in it when the weather clears up.
Al
Al
Sounds good, cant wait to hear the dry weather test drive results. Ive been considering one of these myself.
Dont expect those generals to last long with any aggressive driving. They are way too soft for my taste. The shoulders were bald after 20k miles.
-Lurius
-Lurius
Originally Posted by BadAssChevy327
i was curious why do they say if you have a locker do not install one ??
-Lurius
-Lurius
i kno what they are i had one , but i remember readin dont install a rear sway bar on a truck with a locker/posi , but i never knew for what reason
GXPJAY
11-05-2015 06:49 AM
maxspeed05V
07-19-2015 07:08 PM
