Rear Sway Bar
Rear Sway Bar
I've got an Addco rear sway bar that I'll be installing when I return from an upcoming 4 month deployment (military orders). Aside from the improved handling, are there any other benefits from using a rear sway bar? Will it:
-cure wheel hop?
-increase hauling and towing capacity?
-fix the "Chevy lean" in the rear?
Any info would be appreciated!!
-cure wheel hop?
Originally Posted by BlackLM7
-cure wheel hop? No
-increase hauling and towing capacity? No
-fix the "Chevy lean" in the rear? Doubt it
Some say it helps with highway rear end sway.
I have that very same bar. E to the Z install! It will make a significant improvement in handling. You will notice it immediately.... But, shouldnt effect anything other then that.
GXPJAY
11-05-2015 06:49 AM
maxspeed05V
07-19-2015 07:08 PM
