Rearend noise?
Rearend noise?
So when I did my drop I replaced the carrier bearing because I though it was the problem. I was wrong. I have an eaton posi with stock 3.42 gears. Any ideas?
Originally Posted by gonzo 6.0
Do you check the pinion bearing races?The inner race will get gawled out from hard launches.I gather you have a bearing noise you are trying to figure out.
Describe the sound,You now have a reason to hurry up and do the 4:10s.I am guessing the problem is the race not the bearing but when you go back in there do both pinion bearings and races.
Hey hey hey, lookie here. Don't go breaking open your rear end just yet. Just might need some GM fluid and some F*rd additive. Worked on mine as well, I would get 2 bottles of the ford stuff and then get the Gm dyno oil.
http://www.pacificp.com/forum/viewtopic.php?t=852
http://www.pacificp.com/forum/viewto...3f8b0317227764
I agree,you need to put in the ford additive.Personally I like to use the vavoline blended gear lube.Its what Randy R&P recommended and have had great luck with it.
The pinion bearing noise would be heard while slowly getting up to speed,straight line.
You can but how many miles are on that lube?With the noise its making I bet eaton would recommend you change the fluid and then add the additive.I wouldnt use GM lube its to expensive.You do have a drain plug on the bottom of the diff.At least mine does.
