Reasonable price good quality 3000K stall
Old 03-24-2012 | 01:17 AM
Default Reasonable price good quality 3000K stall
Who has a converter that is reasonably priced read the lower the better. I've all but settled on a TSP 228R cam for a lq4 6.0 that's in my sonoma. The truck is not raced autocrossed or severely beaten on it's just flat driven normal and played with here and there on the back roads only. Texas speed recommends a 3K converter and I know the really expensive units have some great parts in them but they are more than what I need for how I am using my little truck.
We put all the good parts in the trans it's got the normal list of upgrades beast sungear shell and shift kit servos kolene clutch's and wide kevlar band and a stock gm converter till now.
I've never had a stall this large how can I expect it to drive when completed.
Old 03-24-2012 | 02:05 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Your best bet would be to call Circle D and talk to Chris about your setup and your goals. He'll be able to make a good recommendation for you that you should be happy with. He certainly knows more about what is going into your converter than any phone sales guy.... and what the outcome will be, and how your truck will respond.
Old 03-24-2012 | 02:11 AM
JFOLM's Avatar
Like Roger said call Circle D Specialties. They have a 278mm single disk converter that will flash between 2800-3200. It may not be the best for all out performance but it is wonders over the stock one and it will drive well. IIRC it sells for $395.
Old 03-24-2012 | 02:44 AM
call him monday thanks
Old 03-24-2012 | 10:36 AM
redsilv's Avatar
the 278mm 3000-3200 was recommended for my truck
01 silv ecsb 2wd
lq9 370
216/220 cam
ordering it today
Old 03-24-2012 | 12:25 PM
06Sierra2's Avatar
same tc i am running^^, works great and will take some abuse
Old 03-24-2012 | 02:21 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
both circle D and yank make good converters i myself am running a yank
Old 03-24-2012 | 04:16 PM
redsilv's Avatar
06sierra;
did you lose any tow capability
how is it down low rpm? in traffic?
thanks for the input
Old 03-25-2012 | 08:45 AM
Vince B's Avatar
Another vote for Circle D here. I used one of their converters recently in a TBSS unit I did over just using a stock converter. It was double the price of the stocker but it added some peace of mind to the build. Thicker converter hub, better internal bearing, added welds, and a better TCC sold me on the I6 converter for my customer. I did add a billet rotor to the build and a billet output shaft for some additional piece of mind. All in all always nice working with Chris and his crew on projects I get involved in. The converter also came with longer bolts and two different thickness washers if shimming was needed. That is what I call total customer satisfaction!!!!
Old 03-25-2012 | 08:05 PM
Circle-D's Avatar
Former Vendor
Thanks Vince, appreciate the kudos... I agree, the 278mm is a great choice, and with all the durability upgrades we do they are very strong.
To the OP, looking forward to your call on Monday.
Chris
