Rebuild or replace rear end. Please help!
Old 11-27-2006, 06:48 PM
9 Second Truck Club
tarinitup's Avatar
Default Rebuild or replace rear end. Please help!
My grenade 80 blew up and broke my new ring and pinion and self destructed itself. Mechanic recommended a 12 bolt but the least I have seen them for is $1900 for a moser. Will a new eaton lsd, gears, and rebuild kit last a long while or should I just wait and get a bigger and stronger rear.
Old 11-27-2006, 07:45 PM
9 Second Club
Rhino79's Avatar
With a good LSD, and a good set of gears, it will hold up to a good bit of power. The G-80 was probably the culprit of your failure so don't let that keep you from building a stout 10-bolt. I would do just like you suggested and get the eaton, maybe a set of Motive gears (which they have 4.30's now for the 10 bolt) and a good install kit. You'll be fine.
Old 11-27-2006, 07:47 PM
Sexy Party Mod
FarmerBeau's Avatar
Should be good with a reputeable set of gears and good LSD. I would go with a trutrac because it doesnt have clutch material that wears out over time like the Eaton.
Old 11-28-2006, 06:23 AM
BigCountryx's Avatar
a stock 12 bolt is not much, if any stronger than a truck 10 bolt. I'd agree with the others, build your 10 bolt rather than buy a built 12. If you are gonna replace it, I'd personally go with a 9.5" 14sf.
Old 11-28-2006, 07:29 AM
9 Second Truck Club
tarinitup's Avatar
ordered eaton, lsd, and gears. Thanks for info.
thunder550
10-08-2015 04:53 PM
TimDave217
08-24-2015 04:38 PM
DarkhorSe_SS
08-20-2015 08:58 AM
Ketis
07-23-2015 12:37 PM
Sdailey
07-13-2015 09:17 PM
Quick Reply: Rebuild or replace rear end. Please help!
