Redoing my tranny lines, i got some questions.
Resident Retard
I am about to order a Tru-cool 40k and I was thinking about redoing my tranny lines to -6AN braided lines... My question for those who have done it, should i use 45* or 90* AN fittings on the trans? I have seen a few threads where guys used 90*... once installed how difficult are they to get too?
Thanks
Thanks
I used the swivel 90's on my 80 and there is plenty of clearance. If you use 45's, I think you are going to have to bend the hose hard or it will rub on the tunnel. I have some pics at home I will try to get up later.
I used the adapter fittings in the case (1/4" NPT > -6AN) with 45* swivels and straight hose ends, and a braided hose and it always worked flawlessly and I never had a single leak out of it.
I'm actually trying to adapt the same setup to my 80E.
You could probably find that writeup I did by searching this section, or the auto trans section on 'Tech
Advance search threads started by me in this section and keywords '-6AN hoses installed' or something like that in the thread title. Lots of pics.
Resident Retard
Yep i found yours and 1slowz71, but yall used different stuff. You used 1/4"->-6an for the tranny case and 1slowz71 used 14mmX1.5->-6an... Most threads used 90*s on the case, but colton mentioned the 45*s would work better... Just trying to get everything lined up.
