Regular Cab Short Bed 2/4 Drop Questions
Just installed my 2/4 drop kit and I got a few questions.
First off I have Mcgaughys drop spindles, shackles and Belltech hangers. I am running silverado SS wheels with stock size tires (275-55-20).
After the drop it looks like my pinion angle is pointing a little upward. There is a vibration during hard acceleration so I am taking it easy until I get my shims (tomorrow) Did anyone else have to install shims with a 2/4 drop? If so what degree shims did you install? I am getting 2 degree shims but I am thinking I might even need 4 degree shims. I will install the 2 degree shims and see what happens before trying the 4. I also plan on installing some traction bars to help combat axle wrap.
Anyone running this or a similar setup? I did a search and didn't come up with anything too conclusive. Any help/criticism or suggestions on future upgrades would be greatly appreciated.
Here are a few pics of the truck as it sits now.......
So the angle finder is showing me the following.....
The trans tail shaft is pointing downward (towards the rear of the vehicle) .5 to 1 degree
The driveline seems to be flat or maybe pointing upward (towards the pinion) .5 degree
The pinion is pointing upward 4-5 degrees (towards the front of the vehicle)
Let me know if these angles need clarification
My buddy has a set of 6 degree shims but I am thinking that I will need a set of 8 degree shims based on the angles that I found and what everyone else is telling me.
Anyone else?
Anyone else?
Thanks, it's just Dupli-color trim paint that I got from autozone (PN TP70). I just scuffed the **** out of the grille with scotch-brite then laid down 2-3 good coats of adhesion promoter and then 4 or 5 coats of the trim paint.
Used the same thing on my center caps too
