Removed 4WD!
11 Second Truck Club
Originally Posted by IMD
took off 150 lbs of stuff yesterday. and that was only the front diff and axles. also, found out the hard way that 2wd and 4wd hubs are different.
is your truck equipped with the 4x4 electronic switch?
because i am looking for one if you want to sell it.
thanks
Banned
Originally Posted by bluecajun5.3
damn. that must have been a big project.
thanks
thanks
Banned
Originally Posted by aaronmc
Ive been looking into doing this myself. How hard was it?
actually not hard at all. took about 2 hours. you either need to buy 2wd front hubs to replace the 4wd hubs, or, if you are cheap, remove the outer section of the axle that goes into the hub, and re-attatch it with the big nut. if not, the front hub bearings will fall out!
yes, it is electric, and yes, id love to sell it. which part are you looking for? the actual switches in the dash? or the big solenoid looking thing on the transfer case?
i'm talking about the switches in the dash.
shoot me a pm if you'd like and let me know how much you would want for it.
thanks.
Banned
Originally Posted by 04gmc
When you say hubs, do you mean spindles? Does it hurt the transfer case to run without the front driveshaft?
not as far as i can tell. the input shaft is just an internally splined shaft.
and no, the hubs bolt to the spindles, the spindles themselves are the same.
