Ridetech Coil-overs Installed gmt-800
Old 02-23-2014 | 02:40 PM
  #161
MWood's Avatar
Also, has anyone come up with a reliable solution to adding coilovers to the rear? With either trailing arm or 4-link?
Old 02-23-2014 | 04:10 PM
  #162
ShredSled's Avatar
Originally Posted by PaulyC
like i said i havent been able to drive it yet. ridetech told me i cant use an 8" spring on the larger shock i run because i cant preload them but i dont need to preload my shocks with a 4500# truck.
I'm not positive, but it seems you're confused about what they meant by preload. Preload just refers to the tension on the spring and is adjustable up and down the shock body to get desired corner weighting and ride height.
Your shorter 8" coil probably lacks the range to match your longer shock and will run out of preload adjustment (one of the reasons you have to go to such a stiff coil when going shorter with them). To go up, just tighten preload on coil, to go down, loosen it... same concept on a dirt bike or mountain bike if you've ever set up suspension on those for sag/ride height.
Also your short coil may float when shock is fully extended.
Originally Posted by MWood
Would it be better to use their 5.2 stroke shock due to the range of the compression/extension?
Coil-Overs :: Coilover Shock - 5.2" Stroke - HQ Series - RideTech.com - Suspension Specialist - Online Store
Also, do the strongarms have any drop in them?
Thanks.
Depends on your ride height.
For many of us who are lowered around 4"+ up front, the collapsed dimension on that longer travel shock is too long and would bottom out on itself and restrict up travel.
Old 02-23-2014 | 04:35 PM
  #163
skeet's Avatar
Thanks.[/QUOTE]
dont make the mistake of getting these, these will lower the truck at lease 4" or better. Ride Tech doesnt state this, but to match the shocks i have from RT i went with these,Had to modify them to work cause they dropped the truck on my front tires and didnt have enough shock for the ride height i was looking for!
i should have went with these and added a shock mount!
Old 02-23-2014 | 04:40 PM
  #164
MWood's Avatar
For the OP that measured 13" it would seem the 11.225" to 16.425 would be a good choice. Or would you want a lower compressed height over a higher extended height?
From what I read these coilovers alone give a 2" drop which is what I am looking for.
Old 02-23-2014 | 04:47 PM
  #165
MWood's Avatar
Thanks for the info Skeet. I definitely do not want to go that low.
EDIT:
Actually, could you just use a 12 or 14" spring and a 6.3" stroke shock to make up for it?
Old 02-23-2014 | 05:12 PM
  #166
PaulyC's Avatar
after rereading my statement i guess i should have worded it a little better. the tech i talked to was telling me i needed to add preload to the spring, saying i needed a considerable amount. the only preload i have is just enough so that the coil doesnt float at the shocks full extended length.
Old 02-23-2014 | 05:28 PM
  #167
TheBeeblebrox's Avatar
I had thought about using the 5.1" stroke shocks but doing the math at my desired ride hight it was too close to bottoming out the shock - not enough travel
EDIT:
Theoretically yes you should be able to run a longer shock/spring setup to compensate for the drop in the strong arms
To me this would be worth it to gain travel
Old 02-23-2014 | 05:42 PM
  #168
MWood's Avatar
Plus it seems as though the SA provide better geometry for ball joint angle. They are just damn expensive.
Old 02-23-2014 | 05:45 PM
  #169
Yes and ideally you would want to pair them with the uca's as well or run into my problem with horrible balljoint angles lol
Old 02-23-2014 | 06:00 PM
  #170
MWood's Avatar
I wonder if a 6.3" stroke is too much travel?
Quick Reply: Ridetech Coil-overs Installed gmt-800
