Ridetech Coil-overs Installed gmt-800
#21
I know what you are talking about with progressive springs, the hyperco's are linear.
But I guess a better way of explaining it is how much the spring compresses when weight is added, with an 800# spring it takes 800#'s to compress the spring 1", so a softer spring rate with the same weight will compress more and if you compensate that difference with a longer spring it should at least put you back where it was.
I don't know haha, it might just be a backwards way to do things, just an idea I had.
How did you determine the right length shock to get you back to the ride height you were at before? I was planning on giving the guys at RideTech a call and see what they think.
#22
You're thinking the right way. If you have enough length on the shock body, you can preload a longer, softer spring more to get back to the same ride height. I'm following.
I measured my ride hight before, from the lca mount to the shock tower, it was about 13" and I just looked for a shock in that range. It happened to be from 10.43" - 14.53".
ijacosta8 (09-29-2021)
#23
I don't like the weight of these trucks carried by shocks tabs. I'm fabbing coilover mounts for 2.5" 8" King C/O's with a 700lb spring if I ever get around to it. C/O will be at a more effect angle too. If I remember I'll get some pics if anyone is interested. Only downside is shocks are $1400.
#24
#26
Well, I contacted Jon with DB Rods and minis since there is so little info on line still. I plan on making a complete thread with info on CustomGM.com and I will make one here too. I plan to have all this done within the next month!
#27
Good deal! I think the biggest problem is finding the right spring-rate; and getting on scales - at least out here no public scales.
I would mess around with different spring-rates but I just got a project car, so thats on hold for a little while. - I might end up going against what I said and go with a lower rate based on RT's calculator.
Also I've put about 680 hard miles (the off-road park known as the I-5 lol) on this set-up and no problems
#28
