Ridetech Coil-overs Installed gmt-800
#312
I saw where someone mentioned above about the upper ball joint possibly fitting different in McGaughty or Bellech spindles.
Don't forget guys, the upper ball joint hole has to have a 1/2" drill bit run through it for the new ball joint to seat properly.
#315
Interested in doing this swap however I'm running an 05' Sierra that has the odd front suspension setup utilizing torsion bars instead of coils and swing steering instead of rack and pinion. I know Atomic makes some mounts for the 4WD guys but not sure if this is identical to a 4WD front end.
#317
Really good info in here guys. I've put maybe 7k miles on this set up and its the best mod I've done so far...even just slapping them in without the arms, just completed a 350 mile trip and it rides like a dream
Here's how it sits now
#319
Curious guys...when I jack my truck up the springs are loose, like they can move up down and all around. Is this a bad thing? Perhaps I'm not using the correct length spring? Or does it not really matter
