Ridetech Coil-overs Installed gmt-800
#413
Here is the full blown system: https://www.ridetech.com/products/su...ilverado-2007/
I just ordered the rear section, without the sway bar and shocks here:https://www.ridetech.com/application...006-silverado/
Literally just came out this month. I couldn't help myself, perfect timing
prican_2000 (04-24-2018)
#414
I keep coming back to that wishbone setup, it's very tempting. I already have a McGaughys c notch, but it looks like the ridetech notch is long enough to cover the existing cut for the McGaughys as well as some of the holes already drilled for that one. I may have to ask ridetech support about that though.
#415
Some guys on Facebook were asking about the Ridetech C-Notch covering the same dimensions as the McGauphy's or other existing C-Notches. Also, whether or not there was enough room to drill new holes to fit a 14 bolt rear end. I took some pics, hopefully it can help
#416
How close to getting yours installed are you? Mine came in last week and I haven't even had time to get the boxes open and get every thing unpacked.
#417
I also need tires really soon and I'm hoping I can swing the 20's with tires, rather than having to buy another set of 17" tires for now
#418
Starting the install this Thursday, that's the plan anyway. I have 20" Dub Luxe wheels on the way, with the original Proxes ST in 275/45, under $1500 shipped off Amazon.
I'll be taking pics along the way. I'll probably post everything when I'm done and have the ride height set and alignment done.
If you need pics or need to know anything while I am digging in there, let me know now so I can get you the info you need.
#419
Can anyone recommend me a front airbag kit from Ridetech that i could possibly use on a 4wd NNBS?
I figured using Atomic's coilover brackets and an airbag that would clear the front axle would be nice.
#420
hey guys I am almost done with my wishbone conversion from Ridetech and I started a build thread. I should be done and have pics next week
https://www.performancetrucks.net/fo...4/#post5441500
