Is this the right way to set/measure my pinion angle?
Resident Retard
OK so i finally measured my pinion angle... I followed the directions in this video.
http://www.youtube.com/watch?v=UAQgLbhQ0uk
So my rear end is pointing downward 5* and my drive shaft is point downwards towards the rear end 0*.. So my pinion angle is -5* correct? I have read that -2* is optimal. So adding some 3* shims and I should be set or did i screw up in the calculations?
Resident Retard
Well i have read another thread on gmfullsize, where they say to measure the trans tooo. So here are all of my measurements
Trans -5* pointing down towards the rear end
Drive shaft 0*
Rear end -5* pointing down towards the front of the truck.
I don't have any vibrations, i was just board today and figured i would measure it....
Drive shaft 0*
Drive shaft 0*
Drive shaft 0*
Where did you pick up the angle finder?Ive looked, but havent seen them anywhere....
Looks correct to me Corey. Just remember, -2 is just a starting point. Some trucks like -1, and others I've messed with have needed as much as -4.5... The track and your ***-o-meter will tell the tale.
Resident Retard
Thats what I was wondering lol. Ive got a 2/4 drop on my truck, and need to set the pinion angle. Seems tough to get under there and work with it lowered. Im near ft worth too which is why I asked.
Thanks man, i am gonna try the 3* shim...
I have set pinion angles, and watched that video. I surprised that they didn't measure the transmission. They were basically assuming that the transmission was mounted perfectly level. You need to check the yoke at the tranny and see if it is zero. If it is zero then the videos method will work fairly well. If it isn't zero then you can't go by that video. Remember, all you are really looking for is zero degrees when under full throttle. There is more to it than what the video showed. Bushings, Caltracs, HP all have a factor in it.
Ok I just checked a few articles, and now I am way confused. Lol. I guess everyone has a different opinion on how to set it. I have always measured the tranny, and the rear yokes. I will have to read up on this more later this evening.
