Roll cage IDEA, opinions WANTED!
#24
the way I am reading it is you can go 10.00 to 10.99 with just a Roll Bar?
Mark
#26
Resident Retard
The difference in Roll bars and Roll Cages can be seen below or http://www.artmorrison.com/rollcage/racebars.cfm
Morrison 4 Point Roll Bar
The Morrison 4-point Roll Bar is made from 1-3/4"x.134" Steel Tubing and is designed for "Weld-In Installation." Can be bent to retain stock rear seat, if desired. This particular configuration is not NHRA “legal” (8-point bar required). Available in Mild Steel or 4130 Tubing
Morrison 8 Point Roll Bar
The Morrison 8-point Roll Bar is made from 1-3/4"x.134" Steel Tubing and is designed for "Weld-In Installation." Can be bent to retain stock rear seat, if desired and is available in Mild Steel or 4130 Tubing
Morrison 8 Point Roll Cage
For faster cars our CAD-Engineered 8-point cage is the answer. It comes with precision mandrel-bent 1-5/8" x .134" wall Mild Steel Tubing or is available in 4130 Chrome Moly Tubing (1-5/8"x.083") for those applications where weight considerations are of primary importance. You can choose to retain the "Stock Dash and Rear Seat" if desired.
Morrison 10 Point Roll Cage
The ultimate in stiffness, strength, triangulation, safety, and performance. Each kit is made from 1-5/8"x.134" steel tubing or 4130 chrome moly. Added front and rear strutsprovide the rigidity needed to realize thebenefits of fine chassis tuning, a definite plus for the serious-minded racer. Cages include dash bar and driver’s side rocker bar and can be bent to "Retain both the Rear Seat and Stock Dash" if desired.
More rules
http://www.crankshaftcoalition.com/w...legal_Roll_Bar
More rules
ARC
57
02-21-2022 10:54 AM
