RR Dust Shield? Dumb Q...
PT's Slowest Truck
Mine are rusted also, just haven't gotten around to replacing them yet (figure I'll do them whenever I get a trutrac and do it all at once). Anyway, I remember agrief posting about replacing his, and I believe that the shields will unbolt without pulling the axles. Sounded pretty easy from what I remember.
Look at the bright side to all this.....this will give you the chance to look inside your Diff and see if there is any bad **** floating around in there and survey any damage that may be present. Plus, you can clean the chunk up a bit and fill er' up with some new Synthetic gear lube. It's just preventive maintnence ( I think I spelled that wrong).
If you've got some new Dust Shields, hit em' with a good coat of Zinc Primer (prevents runst from forming) and then coat em' with some new gloss black. Overkill is wonderful thing when preventing rust...ha,ha,.
