Russel braided stainless brake lines??
#21
I did these a couple of years ago, and it firmed up the pedal. Then, I got R1concepts slotted/drilled rotors, and all of the brake fade that happens when you hammer on it, and are hard on the brakes went away. I did the hydroboost conversion a couple of months ago, and the brakes are amazing now. I always thought about going with bigger brake like Bear, or similar, but I think mine are good enough.
I think all GM trucks should have come with hydroboost standard.
#22
Ive thought about the hydroboost but im not sure about doing it right now.. ill be checking everything over really good tomorrow for leaks, if i dont find any then ill feel alittle better about the end result of doing the lines.. i may also rebleed the front brakes again just to be sure..
Thanks guys
Thanks guys
#23
I had a time with the rear centerline as well. It ended up leaking some and I had to tighten it some more. The hydroboost mod is probably next on my list because of the constant prases it gets. From what I understand its a must for the hydroboost conversion.
#24
I used the brakes kinda hard today and when everything cooled down i crawled under the truck and checked everything.. i had a very slight leak from my passenger front line where the braided line meets the hard line so i tightened it some more and im gonna rebleed my front brakes again probly in the next couple days so maybe that will firm them up alittle more..
#25
Thats how I found my leak in my center line. Drove for weeks with ZERO issues. Did a panic stop and it just went to the floor. It was like I had slabs of butter for brake pads. Got home and inspected and seen where some fluid had squeezed out.
#26
Dang, thats a bad way to find a leak.. i sat in my driveway and pushed the pedal as hard as i could several times and then checked.. worked ok for me.. i hope i can firm up the pedal alittle more when i rebleed them cause it wasnt as big of an improvement as i hoped more, maybe i just expected too much from the brake line swap.
#27
when I first put on a set of goodridges I ended up blowing a leak in a rear axle hardline that had a small crease int it from the slightly increased pressure... scared the **** out of me. But now all taken care of. SS lines are almost always one of the first mods I do to my vehicles.
oh, and btw, hawkpadsdirect (kingtek) website is selling goodridges for CHEAP! Just ordered and received another set for nbs for $109 free shipped with coupon merry2011
sorry if thats like spam just thought I'd pass on the deal!
Steve-O-08
04-19-2018 09:32 AM
SLOPONY
20
10-18-2016 06:05 AM
thewrx
08-12-2015 08:28 PM
mrgrim
07-08-2015 08:12 AM
