servo install
servo install
Does anyone have info as to how hard it is to install a vette servo and billet od servo? What kind of time frame am I looking at. Did you have to remove the transmission from the cross member? Was it on any kind of lift? Did you work around the exhaust or just remove the y pipe?
Originally Posted by KySilverado
An hour or less I would say. Don't have to remove trans from cross member or remove y-pipe. I had to remove a heat sheild. Did it on the floor with front end on jack stands. Kinda of tight and can be a PITA to get the cover back on and the c-clip back in.
Everything that is said here sums it up. You only remove the heatshield, and go to town on removing things.
I did it on my 03' about a month ago. Took probably about an hour tops. Only needed a small prybar to help push the cover to get the outside snap ring on. A small flatblade too to help pop off the ring to start with.
Biggest thing that helps is to try and keep everything in order when removing the pieces, that way you know how to put it back together.
Definate improvement in the 1-2 shifts.
9 Second Club
It's a piece of cake. When you get it apart, there not nearly as much stuff as you probably think. I installed a corvette servo on The Wood Hauler's truck and he got his from Oregon Performance. His came with an illustration of the parts breakdown. You can find there store on E-Bay. Good luck!
mz00516
08-23-2015 12:19 PM
lycominghunter
08-15-2015 12:26 PM
