Setting up a used ring and pinion
Old 06-20-2009 | 08:14 PM
2005 Silverado's Avatar
SPAM HUNTER
Default Setting up a used ring and pinion
I did the tru trac and 4.11 swap a while back. Lost a pinion bearing . The ring and pinion are set up pretty close to perfect pattern. I am going to replace all bearings. If the ring and pinion are re usable i plan to set them up with a perfect pattern (i have an extra vehicle so i have alot of time to do it right last time it was 2 am when i got them done or well close so i just went with it). So will there be any issues setting it up different then the pattern that was used for break in?
Dustin
Old 06-20-2009 | 08:19 PM
Grumpy5.3's Avatar
Why would you set them up different??? Get your pattern good or where you want it, and go with it.... You might have a little whine to it, but I doubt it.
Old 06-20-2009 | 08:31 PM
Truckshop's Avatar
if you weren't having any issues with it then put it back the way it was.
Old 06-20-2009 | 08:55 PM
kbracing96's Avatar
If you lost a pinion bearing, that wasn't from the pattern being set wrong, most likely you had to much preload on the pinion bearings. That's probable where your vibration you've been chasing came from.
Old 06-20-2009 | 08:57 PM
SPAM HUNTER
Reason i ask. I dont know yet what caused the bearing failure. Unknown debris, heat, bad bearing. So im just asking for the just in case factor.
Also just wondering for personal know how.
Dusitn
Jblake
08-17-2015 12:59 PM
JordanH
08-08-2015 07:59 PM
Sexyrado327
08-02-2015 04:08 PM
Dezert1500
07-30-2015 02:51 PM
JordanH
07-14-2015 03:46 PM
Quick Reply: Setting up a used ring and pinion
