Shift kit install ?'s
I have the Vette servo, what else do I need to remove all TQ management and not kill the trany? Also how many washers? etc do ya'll recomend for firm, but not harsh part throttle shifts? I will be adding a 2800 stall later, and getting my PCM re-programed for the shift kit asap. Thanks for the recomendations. BTW I've heard I need the billit seperator plate etc. And also heard to use no washers?
Follow all the directions to the letter. If you dont like harsh shifts leave all washers in the box. No 1/2 accumulator or servo washers.I have my holes bigger than the directions say and a washer in the 1/2 acc. and my 1/2 shift is to firm for MOST people. Your planned stall will soften your shift some , but for goodness sake go 3000. Just my .02
I'd say no washers, and leave the holes in the separator plate on the smaller setting.
If you got a bigger stall, then still no washers, and use the larger hole setting on the separator plate.
It's a fine line to finding out what you want, and unfortunately, it requires tearing into the transmission again to change settings. Luckily, the 2nd time around is so much quicker.
Andrew
After my experience I ended up with replacing the pistons with metal and I left the transgo boost vavle in. The shifts are firmer than stock. Not quite as firm as my previous programing had them, but I do feel the shifts.
I might try the Corvette servo when the weather cools down. The one I had supposedly had more apply area than a stock vette servo. So I need to figure out if is actually different....
I second the no washers thing.
Late
Late
I left the 1-2 accumulator stock and left out the washers/shims from the servo, as well. Everything was done per instructions and I installed the corvette servo. The only programming I did was remove TM 100%
Shifts firm enough for me. And it's not "too much", as I have not heard any complaints from the fiancé.
It will hit pretty hard in tow/haul mode, though.
Late
Late
