Shift Times w/Transgo?
Old 09-13-2005, 07:39 PM
  #21
what a rush!
moregrip's Avatar
Originally Posted by Naked AV
This is what tells me it is a design flaw....zero TM, and still problems with the 1-2 shift. I don't need to repeat the experiment.
I think the only thing removing all the TM in a heavy, 4L60-equipped truck would do is break the tranny.
maybe so, I wasn't suggesting you try it, just trying to understand the 60 a little more.
Old 09-13-2005, 07:42 PM
  #22
KySilverado's Avatar
I have all TM removed. Did it the day I installed the kit. I'm with NakedAV. The 1-2 part throttle is the issue. Everything else is sweet. You could probalby make yours act like my part throttle does. Run the RPM up in first and just before the 2nd gear shift let off the throttle. It just slingshots into second. Best way I know how to describe it.
Old 09-13-2005, 07:45 PM
  #23
what a rush!
moregrip's Avatar
are you positive all the tqmgmt is out?
  #24
Mr. Sandog's Avatar
Yeah, all I know about it is that it's weak as hell....guys at Tech are breaking them in 3500 lb F-bodies with just bolt-ons. Another 1.25 tons of weight together with more power ain't gonna help matters none.
I was assembling my fantasy Avalanche last night...6.7L, 6L80, big rear end. Guy can dream, can't he? I guess if it's going to happen, though, I'll have to do it myself....kind of like James B. did with his Sub.
Old 09-13-2005, 07:55 PM
  #25
ummm yeah, based upon all that I have read for removing it. not seeing any timing pull or torqe drop in the logs.
Old 09-13-2005, 08:00 PM
  #26
what a rush!
moregrip's Avatar
I understand, not sure if your tables are the same as mine but you can use this as a reference if you use HPTuners:
http://www.hptuners.com/forum/YaBB.p...num=1121993636
Old 09-13-2005, 08:01 PM
  #27
Kano's Avatar
do you drill holes in the seperator plate to determine what firmness the 60e shifts at?
I cant remember exactly but I think it was
.082 towing
.093 street strip
.125?? high stall /performance
so yeah the bigger the hole the more fluid it allows to come thru
therefore making a firmer shift
I went away from the transgo directions on the 1-2 drilling and ran with 0 washers instead of the suggested 2
I would also like to add this
I was also running sonnax accumulators and
a vette servo FWIW
Old 09-13-2005, 08:04 PM
  #28
what a rush!
moregrip's Avatar
.082 towing
.093 street strip
a vette servo FWIW
hmmm, good info, thanks. Now, would having the sonnax accumulators and
a vette servo add to shift firmness than if you did not install them?
Old 09-13-2005, 09:41 PM
  #29
Kano's Avatar
I would say so on the servo
but on the sonnax accumulators
you cant use the transgo springs, you have to use the stock ones
and the heavier transgo springs for the accumulator helps firm up the shifts
but then again
the sonnax piece is machined alot diferently than the plastic or aluminum ones
so its kinda hard to say on the accumulators
Old 09-13-2005, 09:48 PM
  #30
what a rush!
moregrip's Avatar
but then again
thanks
Quick Reply: Shift Times w/Transgo?
