Shocks for a 3/5 help
Old 11-21-2013 | 05:58 PM
N20zuki's Avatar
Default Shocks for a 3/5 help
So I am going to be ordering the DJM 3/5 kit, lower control arms for the front and flip kit and lift shackle for the rear.
Here is what I am torn between, in the past I have used Doetsch Tech shocks and they work great again though this was in the past. But I see DJM recommends Calmax Supershox for there drop kits.
Anyone able to chime in on which would be the better shock to be lowered 3/5, I chose this kit because it allows me to keep the same springs front and rear while it is stiff its not going to bounce my teeth out of my head.
Old 11-21-2013 | 08:57 PM
Three6GMC's Avatar
I really have no experience with the shocks you mentioned but I really like how the bell tech street performance shocks ride and handle. Might want to consider some. I have used them on several trucks I have done and don't have any complaints at all.
Old 11-21-2013 | 08:59 PM
Blackpanther99's Avatar
Belltech. Nuff said.
Old 11-22-2013 | 01:07 PM
TheSuspensionSource's Avatar
FormerVendor
Contact me before you order that DJM kit. I may have better options for you.
Old 11-25-2013 | 11:09 PM
bigmeex's Avatar
Want to do a 2/4 on a 04silverado crew cab on 22 running 305-40-22 or can I go lower w that tire size
Old 11-26-2013 | 11:46 AM
FormerVendor
It is a wide tire. Should be fine though with just a simple 2/4 drop.
Old 11-30-2013 | 12:35 AM
bigmeex's Avatar
Thanks for the info where r u located at @The Suspension Source
Old 11-30-2013 | 07:52 AM
texasglock23's Avatar
^^ Cali!!!!
Also, know that DJM notches are garbage
Old 11-30-2013 | 08:45 PM
N20zuki's Avatar
I've tried searching but I cant find any info on DJM notches not being very good. This is the second time I have heard of this. What is the problem with there notches?
Old 12-01-2013 | 09:08 AM
Let's see your notches - Page 5
Page 5/6 get good
