silverado rear end swap
Old 07-11-2009, 04:38 PM
05RST2NV's Avatar
Pm sent to cheyenne383
Old 07-11-2009, 04:41 PM
05RST2NV's Avatar
That probably be your best bet, unbolt your disk assembly and all and unbolt all the drums off my rearend and swap em.. Once you get down to the bare axle you should be able to figure out how GM did the swap.. Surely they didnt change the axle tubes and brake mounting holes, just the way it all bolts up.. Get my drift??
Old 07-11-2009, 05:46 PM
therock's Avatar
Ahem,
You better get under there and measure the brake backing plate bolt pattern before you go-a-unbolting things.
Your leaf spring and shock mount brackets will most likely be the same but I'll bet the tube ends at the wheels have different patterns.
Save some grief and get a like year model.
Old 02-15-2010, 12:08 AM
chevyridinhigh22's Avatar
whatever happened with the swap, did everything work out?
Old 02-19-2010, 09:40 AM
Restricted User
bohr898's Avatar
if he did try to put the discs on the newer axle.... the answer answer is yes it did work because i have done this my self... only difference is the brake mounting plate is 45 degree different so the calipers sit at a diff spot
pjb1972
09-17-2015 02:06 PM
Oobray
08-12-2015 10:56 AM
So.cal Wrk Sled
07-26-2015 12:10 AM
Ketis
07-23-2015 12:37 PM
Quick Reply: silverado rear end swap
