Six Speed or 4L60E
#23
With the 3.73s and a 27" slick I was at the top of 3rd at 97mph. Now with the 4.56s I will be in 4th, but have not taken it to the track with the new gears, yet! I run a 29" winter tire and a 28" summer tire! I have not had the 28" on yet either.
BTW: 4th in the T56 is 1:1
And yes, I power shift it!
Click here for video
#24
I run a 28 inch tire, with the 373's I went through the traps at 5000 rpm @112mph 4th gear. With the 4.10's I was at 5500 rpm in forth. This was with 12-14psi. I hope this helps. P.S. I just broke my t56 slaming 2nd gear. My clutch cost $1000 but it didn't slip for ****. It held 680hp and 780lbs to the wheels. OZ 700 single disk. Its for sale
#26
Originally Posted by Quik
you want to be in 4th which is 1:1
With 4.56's, 28" slicks and FI I would think my 4.56's would work fine, but first gear is over real quick.
Originally Posted by 04GIBBS
So how do you think I would do with 373 gears and the factory JG 20' tires sized at 295x40x20?
#27
Gears
Damn so it would not work well huh? I just had these 373 installed because when I bought the truck with 700 miles the guy had 456 gears in it. I took them out becasue the 4l60e with my setup loves the 373 or 410 gear.
#28
#30
5 year bitches!
Originally Posted by vanillagorilla
Not with a torque challenged 4.8L. I need all the gear I can get.
With your sized tires, a T56 and a SC you're going to want more gear. I say 4.10's, but you might want to consider the new 4.30 that Motive makes now.
