Slight "ringing" noise in rear
I have a 10-bolt differential with a trutrac, superior axles and superior ring and pinion (3.42)
At about 35 & 67mph I hear a light "ringing" noise that sounds like its coming from the rear end. Nobody even notices until I point it out to them.
The truck drives flawlessly and I have been hearing the same noise for thousands of miles with no change. I usually just don't drive at those speeds.
Any ideas? Should I be concerned? I plan on pulling the pan off and changing the fluid in the near future. What should I be looking for?
MASS seller approved
Mine are superior too and the grease pattern was perfect both accel and coast and mine ring or sing whichever u want to call it. A lot of the aftermarket gears are hardened a lil different from stock and they sing a little bit. I would say as long as the grease pattern was good when u set them up then just live with a little singing in the rear. The only ones I heard of not sing are oem and a few others
black03rcsb
09-01-2015 10:17 AM
superchomper2003
08-26-2015 09:39 AM
V-seriesTech
07-28-2015 12:31 PM
