Slight Shudder after Lowering
2014 RCSB.
I had the new Belltech 988 kit installed for a 3/6 drop. It's the new model spindles & coils up front and a flip kit in back. I left the factory shocks on.
I started to notice a shudder from about 20mph to 35mph; peaking in intensity about 30mph.
It's not severe or shaking, more felt in the seat of the pants. Above 35mph I don't notice anything. I've had it up to 80mph with no drivability issues.
Any ideas on what I need to be looking at?
Sounds like it's only a very small amount. If you're lucky the pinion will be slightly too close to level in which case the simplest method will be to shim the transfer mount. Loosen the collectors on the manifolds before doing that, then retighten after.
Finally able to get on a 4-post lift and measure.
Trans: 4* down
Driveshaft: 4* down
Pinion: 0*
So it looks like I have a problem. The kit came with a trans mount space that's about an inch thick. Wonder if I remove that it will be kosher?
I'll be following up with Belltech & the installer.
Trans: 4* down
Driveshaft: 4* down
Pinion: 0*
