So im on my 5th transmission..
#22
lemme know I'll probably have my motor built either here locally or maybe let HKE in houtson do it, they seem to have phenomoinal results..
#23
Wow, hate to hear of that much trans trouble man. Hope the 80e serves you well.
If you have electrical issues with the PCM/TCU stuff I'm guessing you could have all the trans programming tuned out and run a manual valvebody with a slap-shifter. Not the best for normal driving, but for racing they're awesome.
#24
Thanks for asking. I do not install cages, however I do have relationships with shops that can and do install cages. I could strip it down and deliver it to my guy, have the cage installed and reinstall the components removed for hr cage install. No big deal. And yes I can do the motor swap as well. If you'd like to call I wouldn't mind helpin you plan the project.
g
g
#25
I honestly would never think about putting any kind of real power through the Jatco RE5R05A. These units have issue in stock form and we see them often in the shop I work in. I will also add the the radiators in those vehicles suck. We constantly see units in where the trans oil looks like a milk shake. Seems to be a common issue for these. If you plan on using the factory radiator do yourself a favor and bypass the radiator all together for the trans. Install an external cooler to avoid screwing up your new 80E. HTH Vince
#26
Stock rotors and brake system ------ replaced
rear end differential --------------- replaced
radiator----------- replaced
shitty radiator fans--------- replaced
only thing i can think of that might still be a weak link is my stock pistons and rods, but those are going to get taken care of this summer as well.
1000rwhp, built, jakes, jatco, menards, optishift, performance, re5r05a, replacement, review, reviews, transmission, turbo, twin, vk56
