solid motor mounts on trucks?
you knew you would find me didnt you?
i run solid mounts. not truck and car are totally different
mine are stock mounts that been plated on each side. as for driving not sure quite yet since i only have put about 15 miles on the truck but i will say it doesnt rock like rubber mounts do and it feels much more stable
but i have witnessed m ytruck rock back and forth slightly
its going to be hard to get pics of them with my damm headers in the way. pics of the mounts are a series of pics i didnt take during the build which i probably should of
none of the motors torque would be lost through the twisting of the engine. if you sit in front of your engine and pull the throttle cable (if there) you will see your engine twist. solid mounts would keep this from happening. kinda like what a polyurethane trans mount is for.
Thats good then. It would also be cool to see your truck rock to the cam lope like quik's.
Hey Quik, what gauge of metal or how thick was each plate? I'll have to wait until you make a couple hard passes for your feedback on if your plates distorted or not
