some advice 17" wheels & tires for traction
hello guys, we live in Monterrey México, and we have just build a 2010 chevy cheyenne, the problem is that the differencial was changed for a disc brake that came off a 2009 yukón denalli, and we dont know what kind of wheels and tires are best for the track in 17" wheels, we can´t use 16" or less, because of the discs, the truck has the 3:42 rear gear ratio, cal-trac bars, 3000 stall from circle-d, 441lsx engine and a lot of toys, the truck is just 2K miles on the odometer, but it have never been on the track, because we do not know what kind of tires to use, it´s ok the hoosier 28 x 10 R17?
Ok, thanks, i think i will order this tires, and what wheels you think would be the best choice, i´ve seen a 17x9 wheels with 4.5 BS and -12 offset. Do you think this wheel will fit good keeping the tire inside the bed, i dont like the look with the tires out of the bed (fender).
thanks my friend, i will try to get the OEM wheels.
OK, i will check there, in the 2010 chevy silverado the MAF is Removable it´s not like in the 2008 i had, in 2010 it is a single piece that is inserted on the pipe.
BoostedBowTie
01-03-2020 06:46 PM
Steve-O-08
04-19-2018 09:32 AM
