Spongy Brakes !!
Old 11-05-2006 | 06:28 PM
Originally Posted by fake_usa
I just order some rotors off ebay, R1 Diamound slot / cross drilled with zinc coating.
They we only 15 bucks more then the cheep china replacments at strauss auto.
I would have liked to get a name brand but my budget is a little tight right now.
I wish I could get that last bleeder opened, anyone have any ideas?
Get an Ease Out bit that fits the hole pretty tight of the bleeded valve.
That might work.
Jim
Old 11-06-2006 | 08:20 PM
fake_usa's Avatar
Is this what you're talking about..?
Old 11-06-2006 | 08:55 PM
Mort's Avatar
Cool
I would carefully drill the bleeder out as much as possible and then take whats left out with the easy out. If the bleeder is that hard to turn then the easy out is likely to break off in the bleeder and you are fubar. The easy outs are hardened steel and snap off pretty easily if you twist them with too much torque (don't ask me how I know that...LOL). They are very hard so forget trying to drill one out if you break it off in the bleeder. If you drill very carefully and keep the drill square to the center of the bleeder it will guide the bit. Just go up one bit size at a time until you see the threads start to appear. At that point the bleader should be fairly loose in the hole and the easy out should remove it without too much trouble. Using a little cutting oil can help with the process as well. It works I'v done it a few times.
Good Luck!
RustyD
05-23-2016 08:04 PM
turbo6c3
10-05-2015 07:11 PM
KINGCYCLES
10-02-2015 11:21 AM
Noah Burns
09-13-2015 10:28 AM
Alco
09-04-2015 05:08 PM
