Squeal coming from tail of 2006 4l60e 2wd
![Question](https://www.performancetrucks.net/forums/images/icons/icon5.gif)
What could this be? The squeal occurs in drive only and when under slight load only, such as accellerating normally. The squeal gets faster proportionally as speed increases. The truck shifts and drives fine. Is there a bearing or something in the tail that is about to fail? Can this be fixed without pulling the whole tranny? Thanks for any replies.
Some of the 06-07 models had problems with the speed sensor rubbing on the reluctor wheel. It would make a high pitched whine noise. You can removed the sensor to see if it goes away.
