Stabilitrak light after AXN swap
#21
The sensors are very different on the axle side. Also i doubt the wheel count is the same.
#22
Is it a built 4l60?
I feel its very strange that theres no information regarding this specific stabilitrak issue. Is it possible a sensor somewhere else is unplugged or a wire got rubbed threw?
#23
The convertor is a circle d.
They look everywhere on the lift. Even pulled the tank to put the new pump in.
#27
Did you ever find a solution to this? Just did AXN from an 09 Caddy into my 05 Yukon XL and I have exactly the same problem. No ABS activation + a big *** air bubble stuck in the module stopping me from bleeding properly. Can't run the ABS bleed with those DTCs present and I can't clear them. Reading constant 3 mph from the sensors no matter the speed. Truck needs to haul for 20 hours of driving next week....
#28
#29
Thanks for getting back to me. Yeah I hear 4l60s are pretty much dead ends after 400 wheel or so. I threw this axle in because it was cheap and I read it was a direct swap. I'm not even considering turbos until I can afford a full 4l80e or I have time for some kind of even dumber swap. Mostly she sees duty hauling things for a kids nonprofit I run. I'm sure I'll have to do some kind of redneck electrical engineering magic to get the lights off. For now I'll bleed it the hard way and just avoid towing
SLOXCAB
10-12-2009 09:15 PM
TouchOfEvil04
10-28-2007 07:10 PM
