Stainless steel brakes?
Anyone have SSBC's short stop set-up? They offer a 4-wheel kit with all 4 rotors that are slotted and high performance pads for under $400. I would like a set-up like J Smith's but this SSBC kit is cheaper. Any thoughts on this kit?
i put a set on my rear. only pads and rotors. kept caliper stock. the whole set was a good price. i can't tell if they make much of a difference since they are on the rear. no problems yet though. had them on for a year now. i think they are better than the drilled and slotted. the drilled ones are weaker. these are just slotted. if i was to do it all over again, i would buy the kit that comes with the calipers too.
Thanks for the pics. I probably going to get them, good price. I'd like to get the calipers to , but they are expensive. I need to replace my rears, have 104k miles and the pads are finally worn out.
Save your money.
1. Replace your rears with all OE equipment.
2. That front caliper upgrade would be perfect, without upgrading your rotors.
Slotted rotors will wear your pads faster, and increase dust significantly while not offering you any stopping improvements on dry flat surfaces. But they look sexy
The rear braking system only accounts for <20% of your total braking. Spend the bulk of your money up front where it counts.
You may even lose some unsprung weight by switching to this caliper. That is a good thing!
the stock rotors for the rear are super exspensive. i think it is cheaper to get after market.
i never got the optional plating. i don't remember it being an option when i bought them
Originally Posted by unredeemed
Save your money.
I understand what you are saying, but this is the 3rd 99-02 model truck, I've owned, that the rears have worn out faster than the fronts. I think it's due to GM's crapy job on the 4-wheel discs. Maybe that's why they went back to drums ??
I agree with you - factory rotors are around $135 each and pads are $150. For that amount I can the full SSBC kit for all four wheels, instead of just the rears. I think I will definately get the SSBC kit and get some new stainless lines and eventually upgrade the calipers.
Thanks for your input.
Save your money.
As unredeemed alludes to here, slotted rotors of the same diameter as stock with new pads are actually a cosmetic upgrade, and a performance downgrade.
Your best FUNCTIONAL brake upgrade for under $300 is:
1) Stainless steel brake lines
2) Upgraded pads (keep stock rotors)
3) Upgraded fluid (i.e. ATE Super Blue)
